No water on the job??
hr
Member Posts: 6,106
this well tank "pressure maintainer." It will supply about 5-1/2 gallons when pressurized to 50 psi. I installed a small, accurate water meter to record how much the system has taken on.
It could be used as a troubleshooter on a slab that you suspect has a leak.
If the bladder is compatiable it could also be a glycol maintainer.
Tank runs about 130 bucks at graingers, add a prv if needed to tie into the boiler drain.
The Curvo formed copper line also doubles as a carry handle.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Time!
HR I wish I had the time you do! The Clip Tie has saved me alot of time.
John Jr.0 -
I see those all the time...
In shopping center malls. Thats what they use to service the plants! "Ceptin it has wheels and doesn't have to go up and down steps:-)
I found a picture the other day of Matt Rossi firing off the worlds biggest squirt gun, a #60 expansion tank with a ball valve on it. It can get the water out about 60 feet away..."Course the tank was charged to around 100 PSI:-)
ME0 -
When do you
have time to go to shopping malls?? And what exactly are you doing there? Are you a mall walker?
hot rod
I'm a mallwalker
My wife, "Sweet Carol", convinced me it would help me lose weight to walk the mall. So we do. It works. I shed a pound OF CASH every time we do it. 8-)
Tom Meyer
Senior Designer/Trainer
Precision Hydronics Corp
www.precisionhydronics.com
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
