Things that go buzz in a circulator
hr
Member Posts: 6,106
up and running fine for months. Owner calls and says the pump is screeching. Sure enough I pull the head and find this plastic pipe cap jammed in the volute.
Had to go around several 1-1/4" BI 90's to get there. Must have softened enough to squeeze through.
The Grundfos held it's own, ground the cap up a bit, but ran fine after the removal. Must have come inside either the Clean Burn boiler or the Raypak storage tank?
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Looks like....
A hunk O dip tube to me.
The next call you hear wiil be the sound of the customer with "little or no" hot water. (?) Chris0
- 167 Indoor-Air Quality
