Renter with 1 pipe steam heat has many questions
Hi. I'm a renter with 1 pipe steam heat. I'm having overheating problems in the bedrooms and underheating problems in the main (living, kitchen & bath) rooms. I want to reduce the amount of heat in the bedrooms and have it come out in the main rooms. Can I do this by adjusting the valve on the radiator? If not, what else can be done to adjust the heating?
Thanks in advance.
Russell
    Steamhead Member Posts: 18,217
    The radiator shutoff valve
    must be kept fully open or fully closed, or water will back up in the radiator and cause banging.
    If you have adjustable radiator air vents, you could try turning down the ones in the bedrooms or turning up the other ones.
    The best bet would be for your landlord to call a steam-oriented contractor to look it over. Try the "Find a Professional" page of this site.
    Consulting
  • Russell Berryman
    Russell Berryman Member Posts: 2
    Ok, so the valves must be kept full open. How do I adjust the air vents?
    If they are adjustable
    you will find a graduated dial either at the bottom of the vent, or forming part of the top of the vent. It depends on who made the vent.
    If you're not sure, post the makes and models of the vents and we'll tell you what you have.
    Consulting
  • ross
    ross Member Posts: 37
    steam heat control
    Unfortunately, there's not a lot of control to be had with one pipe steam radiators - they're either on or off. My mom's place has 2 rads upstairs and 2 downstairs. Most of the time she just has one of the downstairs ones on to heat the house, two when it gets real cold. I think Dan refers to the "double-hung thermostats" in these systems (windows)!
