Insulation under Quick Trac ?
Joe B.
Joe B. Member Posts: 9
We have used Quik Trak on jobs where we were able to install the proper insullation below the subfloor, but what about existing slab on grade jobs. The Wirsbo manual talks about a possible vapor barrier if the water table is high, but there is no mention of insulation. Do we need to be concerned with downward energy loss.
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    Yes...
    You do need to be concerned with downward losses.
    R1 would be better than no R at all.
    ME
  • Dave H_2
    Dave H_2 Member Posts: 622
    Floor Coverings
    are also a concern.
    The amount of insulation will also depend upon the finished floor covering to go on top of the quik trac.
    For some projects, I have used a layer of plywood below to act as a thermal break and also something to attach the radiant system to.
    Dave Holdorf
    Taco, Inc
  • Above reply is usually adequate, depending on floor coverings. However, as big a Wirsbo fan as I am, the application you are talking about is one in which I tend to think quik trak was not well designed. Maybe RauPanel, which has the aluminum on top?
    _______________________________
    Northeast Radiant Technology, LLC
    Robert Brown, Co-Owner, RPA certified Radiant Designer
    207.899.2328
    NRT@maine.rr.com
  • Joel_3
    Joel_3 Member Posts: 166
    heat
    Is going down no matter where the aluminum is. Those neat plywood squares with the dimples on the back do give you insulation value i just can't remember how much. We used athin foam like what goes under Pergo and no problems
  • It'll give you about a .5 R or so. do it over a ply sub and you've got about 1.4 down and .9 up w/regular hardwood on top. Not ideal, but adequate in most cases. I'd prefer than to flipping it around at least if it's not possible to get insulation in.
    Any links regarding that athin foam though? I'm not familiar with that and google isn't being very helpful.
    207.899.2328
    NRT@maine.rr.com
  • Mark Eatherton1
    S P A C E. . . .
    I think Joel meant A THIN FOAM. He's like me, my mind can't keep up with my fingers, and my fingers RARELY talk to my mind...
    M E
  • Michael_6
    Michael_6 Member Posts: 50
    aluminum
    Joel, before you say where the heat goes try a simple experiment. Put a couple of passes of Raupanel and a couple of passes of quik trak on 3/4" ply no insulation below and nail some hardwood over it. Use same tube lengths-same water temp and pump. let run for a bit and check surface temp of hardwood in a few different spots, surface temp of panels in a few different spots. Then check the temp under the plywood and let me know what you find. ( your temp gauge won't get an accurate reading from the aluminum unless you make it black)
  • Weezbo
    Weezbo Member Posts: 6,231
    first let me say :) Thanks .Space:)
    the "plan" i have today is sorta like the Question you have. i intend to use 3/8ths pex ,with the foam that comes from the shipping package of overhead garage doors! this i will lay around the perimiter of the room .as it is about 2-0' wide .it hopefully :)) will allow the heat to sink into the middle of the slab down to my existing insulation and vapor barrier.that i have no "Engineering data" on however.it just seems the panel will Radiate more near the walls as it will be Thinner,in the middle of the room the thermal mass should Sorta Saturate ......the thing though is that i intend to use a very thin 3/4 " pour of gypcrete with Moose milk...(acrilyic bonding agents) entrained.....if it dont work...well...its My Home :) i can always find some way to save a dollar:)
  • Mike Reavis_2
    Mike Reavis_2 Member Posts: 295
    Try Roth Panels
    They have styrofoam underneath, and aluminum on top to snap the pipe into. They work at my house.
