Circulator pump for hot water loop on steam boiler
TJ_2
Member Posts: 26
What circulator pump is best for a hot water loop on a steam boiler?
Red Fox
Bronze Fox
B&G100 Iron
B&G 100 Bronze
Thanks, tj
Red Fox
Bronze Fox
B&G100 Iron
B&G 100 Bronze
Thanks, tj
Condensate Circulator
A B&G 100 or any three piece circulator would be my first choice. You don't need the bronze on a condensation loop. You want to stay away from the water lubricated type circulators . The grit and solids in the condensate cuts the life of these types of circulators..0 -
Bronze or iron
According to ITT, a bronze body pump is more suited to handle condensate.
I think it's a waste of money and have never attributed a failed system to a compromised pump that was misapplied.
3 piece pump
w/ bronze impeller. The body can be iron, or whatever that is they use. Learned the hard way that bronze impeller is the only way to go.
- 120 Geothermal
