Boiler Pic's
S Davis
Member Posts: 491
This is our latest boiler install,7000sq.ft. Radiant floor system in seattle Wa.
clearly. on the beam:)
low water. secondary high limit. Pump away .on and on
straight and simlpe.:)
so maint is the pleasure side of the cruise:)0 -
Nice
I like the joints nice and clean. Very nice job, one question, why did you dip the bypass like a heat trap and not go straight accross? It looks nice as it is I just wondered if the was a function to it? Is that a tempering valve? It looks like a reg gate?
VERY nice,
RICH0 -
Differential Presure By-Pass
The valve all the way on the left is a differential Presure By-Pass it Keeps your velocity from getting to high when only small zones call for heat.
The Heat trap helps keep heat from migrating from the high temp loop to the floor loop.
S Davis0
- 167 Indoor-Air Quality
