Hand Pump?
Andy_6
Member Posts: 48
I was wondering what what you guys use to inject boiler treatment into preassurized boiler systems? Is there a small hand pump available for when you only have a quart of fluild to add? Thanks
Silver King
has a nice brass one. I added a valve and some insulation for hot use! 215-343-5337. A garden hose female connector on the discharge end help for ease of connection.
Some cleaners do seem to cause the o- rings to swell and make for hard pumping. Be sure to flush it out with clean water after use.
The foam insulation also prevents dings to the soft brass tube which hampers pumping action.
hot rod
Sid Harveys...
has a nice one too.
ME0 -
Thanks I will check them out!0
