Runtal panel connections
kevin coppinger_4
Member Posts: 2,124
when connecting 2 runs of uf series base boards what do you guys use for cinectors on the horizontal to keep these as close as possible? Double male unions?Is there such a thins...copperx male adapters will burn the paint...any suggestions? tia... kpc
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=323&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Runtal
I have used Right&Left nipples and couplings, just through away the coupling and use the nipple.
S Davis0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
