Quick Track panels w heated shower pan
hr
Member Posts: 6,106
the walls and bench! Need to heat them also :)
What's up with that PVC line in the back wall? Or is that a central vac?
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Easy trick
When using the Wirsbo Quick Trak panels, we find it easy to jump into the shower pan by laying out the panels until were at an easy entry/exit for the pan. Lay the loop and continue back the through the QT panel. Makes for some extra comfort.
usually..
we do the bench seats and the walls. sorta busted the bank on this one and reduced the scope:) the PVC is central vacuum. We're using the Oventrop Unibox to control the QT temps off the radiator mains.
Paul
we usually run the panels right under the shower and allow the copper pan to sit on top.
Scott
sometimes...
...we panel under the base. there'll be a mudset and PV shower pan
- 167 Indoor-Air Quality
