Grundfos flange on Taco?
Brad_3
Member Posts: 24
I didn't look at the goods from my distributor well enough this afternoon and it turns out I received Grundfos iso flange kits instead of B&G. Will these work OK on a Taco 005?
Thanks,
Brad
Thanks,
Brad
yup..
should be no problem0 -
I almost always use the tacos....
w/ the 15-58's...my supply house doesn't carry the grundfos flanges...kpc
You should use
the Wetstone flanges with the built in bal valves. When you need to replace the circ down the road you don't have to drain the system. That's good livin. WW
Taco Flanges
Good Afternoon
Thank you, for using Taco, products. The Grundfos flanges are compatible with the Taco. That is one of the attributes of a Taco circulator. It is designed for easy replacement of an existing circulator. Please advise, if you have any additional questions, or concerns.
Joe Mattiello
Technical Services
(401)942-8000 ext.484
Fax (401) 942-2360
joemat@taco-hvac.comJoe Mattiello
Taco Comfort Solutions0 -
Bolt patterns vary
a tad from brand to brand. The Webstone has cleverly provided oval shaped holes! For perfect alignment, regardless of the pump brand.
I like the latest B&G even better with a flange that rotates to any position. No that makes pump brand switching a piece of cake. I no longer have to stock Grundfoe FR (flange rotated) circs to replace failer greenies
hot rod
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 991 Plumbing
- 389 Solar
