Multimeter
Gary
Gary Member Posts: 29
Looking for a good multimeter for trouble shooting radiant heat controls , like low voltage to sensors for outdoor resets. Thanks
  • Gary
    Whats the best multimeter for radiant heat systems
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Electronic resets should be using a thermistor--merely a device whose resistance varies predictably with temperature. You can check one with any ohm meter, a glass of ice water and your hand. If resistance changes proportionally with change in temperature the fault lies elsewhere.
  • Jack_23
    Jack_23 Member Posts: 153
    You want a meter
    designed for the "climate Comtrol" industry. Mike is spot on with the ability to read temps on thermistors with resistance. Manuf should publish thatt info. Be sure that you get a meter that can read microamps. You will need that for the flame rectification systems found on all gas fired (electronic ign) units. UEI and Fluke are probably the two biggest names today.
  • Boiler Guy
    Boiler Guy Member Posts: 585
    UEI question
    I have used a number of UEI meters and find them to be somewhat unreliable. I have never been let down by my Fluke equipment yet though. Has anyone else out there experienced this?
  • Gary
    fluke
    What model fluke do you use Boiler Guy ?
  • Dan_12
    Dan_12 Member Posts: 9
    meter
    I'm very happy with my Amprobe 57 = dual temp., flame rect., 10 amp thur meter, ect.
  • Ball Valve
    Ball Valve Member Posts: 18
    I use a UEI model DL250. It does everything i expect from a meter. The only time i have found it to be unreliable was after a fall from the ladder or getting wet from a broken pipe. Rain did not seem to hurt the meter. Not many meters can take that kind of abuse.
  • Kal Row
    Kal Row Member Posts: 1,520
    feature-full..
    multimeters that are reasonably priced, are the norm now, i save fluke for the esoteric test equip, save your money, you are going to need it for an decent infrared temp gun with a laser pointer, something no heating professional should be without - not to mention, a serious combustion gas analyzer,
    a milliamp sensing meter you can get at radio-shack or the HOME-DEsPOT - the less you spend - the less you will be upset when it gets "misplaced" voluntary or otherwise
  • Mark J Strawcutter
    Mark J Strawcutter Member Posts: 625
    Fluke
    While some of the Fluke meters we use at work could indeed be classified as "esoteric", they make some good, reasonably priced meters designed for the HVACR trade.
    I have a Fluke 16 multimeter (with temp) and a 322 clamp meter. The are available as a set with case, but I purchased mine individually for about $50 each on ebay new.
    Dual temp would be nice for A/C work but the 16 doesn't have it.
    Mark - saving my pennies for an 80PK-8 pipe clamp temp probe.
  • Field Piece
    I use Field Piece. It has different heads, dual temp, for supply and return or HVAC. It has an anemometer for checking air flow, an clamp on ammeter. I bought 2, one for a back up and have never had to get out the second one in 5 years. They are very slim, so they fit in a tool bag pocket.
