McDonnell Water control Leak
Rich Baker
Member Posts: 12
We have a McDonnell Water control on our one pipe steam system. Lately the blow off valve has had a very slow drip. However, I blew down the system prior to going away for the weekend hoping to stop the drip. Now the drip is more of a stream (more than a pail full over three days.) Is there anything I can try before I call the plumber.
Thanks Rich
Thanks Rich
You can
turn off the boiler, drain the water to a level lower than the low-water cutoff and take the blow-off valve off. Flip the rubber valve seat over and put it back together.Retired and loving it.0 -
Dan: thanks for the fast reply! If we were not going skiing, and I had all of my tools I would give that a shot (we recently moved into the new house and not every thing is moved over yet), but it looks like I will need the plumber this time.
Rich0 -
Rich0
- 167 Indoor-Air Quality
