will antifreeze evapoarte in a system( if so how long)
Jim_30
Member Posts: 1
Will antifreeze evaporate in a weil mclean boiler and if so what is average life expectancy for antifreeze IE 10 gallons put in system 7 years ago would there be any left.
It doesn't evaporate......
it deteriorates. Like the stuff in your car, hot/cold cycles change the chemistry and eventually it becomes acidic. Depending on the brand and type, the manuf. vary on how long between changes, seven years is a looong time. Testing for PH level is a first step, check the threads and manufacturers list, there is a water treatment company on here with good advice. They would probably test it for a fee, probably very worthwhile.0 -
Antifreeze
Jim
If you would like it tested, send me a sample. Give me a call 800-678-6625 Ext 108 or email me for the details.
Drew0
- 167 Indoor-Air Quality
