power vent
cowie_2
Member Posts: 1
Can anyone tell me what the distance between two power vent terminations are?? I need to install a power vented gas water heater in a mechanical room along with a gas fired power vented furnace. This utility room has 13 feet of exterior wall for me to exit with power vent terminals. Also, this is going to be installed in a laundry/utility room. Are the new gas water heaters (vapor technology?)ok for this type of installation?
Thanks,
Cowie
Thanks,
Cowie
try Field
I'm an oil guy but I'm pretty sure they have a control kit to vent multiple gas appliances through one venter.
Tom M.0 -
There is no distance requirement for termination, just combustion air. You can use one venter for both pieces of equipment. I prefer the Field Controls PVO with adjustable post purge. The SWG has control kits that do this, but it takes a bigger hole in the wall and everything is outside in the snow and rain.0 -
Tjernlund SSII and Mac 1E
for control of two appliances with one venter. Simple wiring. Pre and post purge built in0
- 167 Indoor-Air Quality
