Since we're talking Munchkin
hr
hr Member Posts: 6,106
I've been pre-fabing this 199 for an install this week. The 1-1/4 loop will be t-drilled at the location to pipe in two secondary circs for this 2 zone 10,000 sq. ft. farm and feed store.
Notice the 3/4 1/2 3/4 pex fitting for the condensate drain air gap.
Also a Watts "drain port" ball valve for pump isolation and a low point drain.
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
