replacing steam air valves
bill h
Member Posts: 1
I HAVE A 1 FAMILY HOUSE. THE SECOND FLOOR RUNS 10-20 DEGREES HIGHER THEN THE FIRST FLOOR. WHEN I REPLACE THE STEAM AIR VALVES WOULD I PUT A HIGHER # OR LOWER # VALVE TO HAVE LESS HEAT COME OUT OF THE UPSTAIRS RADIATORS.
GREAT WEB SITE! THANKS
new vents
Generally speaking, set adjustable vents to a lower setting to reduce heat output. If this doesn't work, consider thermostatic radiator vents for the second floor. They will prvent overheating.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
