Constant Tension Clamps for SolarRoll
We're rebuilding a delicate system and my partner said he thought he'd seen some constant tension clamps available on some newer Solaroll systems.
Any one know of a source of supply?
TIA
ME
  • hr
    hr Member Posts: 6,106
    Some ideas
    Here is my solar roll assault package :)
    I use the brass couplings found at auto parts stores. They also have these nylon ratchet type clamps. They have some spring to them, much more so than a basic stainless steel hose clamp. At system pressures below 15 psi these have worked fine for me.
    The black spring clamp is an old Heatway Twintran clamp. May be hard to come by. How many do you need?
    The large stainless is a current Watts Radiant offering for constant tension. Obviously for 1" tube :) They may have a lead for small diameter versions.
    Playing with fire working on those old "roll" systems, aren't you!
    hot rod
    To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"
  • J. WALTER BOOTH
    J. WALTER BOOTH Member Posts: 23
    SOLAR ROLL
    WE STILL HAVE A COUPLE ROLLS (4) OF SOLAR ROLL IN STOCK
    IF YOU NEED SOME FOR REPLACEMENT. THE CLAMPS HAVE LONG
    GONE FROM INV. ONLY WISH THE TUBING WENT WITH IT
    WALT
  • Bill_24
    Bill_24 Member Posts: 26
    Constant tension clamps
    Mark,
    What size tubing are you working with? I have some for 3/4" heatway.
    Bill
  • 1/4 \" ID
    Thanks anyway:-)
    ME
  • Steve Eayrs
    Steve Eayrs Member Posts: 421
    I have a few of the old clamps and inserts of the old 1/4" soloroll tubing, but not sure I want to part with them. Regretfully I know I will need them someday. I know there are at least a dozen places with that junk around here.
    Steve
