Constant Tension Clamps for SolarRoll
[Deleted User]
We're rebuilding a delicate system and my partner said he thought he'd seen some constant tension clamps available on some newer Solaroll systems.
Any one know of a source of supply?
TIA
ME
TIA
ME
Some ideas
Here is my solar roll assault package
I use the brass couplings found at auto parts stores. They also have these nylon ratchet type clamps. They have some spring to them, much more so than a basic stainless steel hose clamp. At system pressures below 15 psi these have worked fine for me.
The black spring clamp is an old Heatway Twintran clamp. May be hard to come by. How many do you need?
The large stainless is a current Watts Radiant offering for constant tension. Obviously for 1" tube
They may have a lead for small diameter versions.
Playing with fire working on those old "roll" systems, aren't you!
hot rod
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
SOLAR ROLL
WE STILL HAVE A COUPLE ROLLS (4) OF SOLAR ROLL IN STOCK
IF YOU NEED SOME FOR REPLACEMENT. THE CLAMPS HAVE LONG
GONE FROM INV. ONLY WISH THE TUBING WENT WITH IT
WALT0 -
Constant tension clamps
Mark,
What size tubing are you working with? I have some for 3/4" heatway.
Bill0 -
1/4 \" ID
Thanks anyway:-)
ME0 -
I have a few of the old clamps and inserts of the old 1/4" soloroll tubing, but not sure I want to part with them. Regretfully I know I will need them someday. I know there are at least a dozen places with that junk around here.
Steve0
- 167 Indoor-Air Quality
