another install pic clammy
clammy
Member Posts: 3,256
there's nothing wrong withthese pics right they just about refuse to do any work on this unit last cleaned 5 years ago well no water no low water cutoff = new boiler install
R.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
here's the new unit
here's the new boiler a little tight and a long haul into the home through a court yard then up 6 and down 1 flight with a turn through a finished basement bed room and into a closet thank god it was no fartherR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
nice
cleanup .Hope they learn to have annual service done.0 -
service haha
i think it's against there religen the hole was caused by a leak in a hot water line that just dripped they covered the control with tin foil so it then diverted the drip right onto the oil pump they get a cleaning card every spring and never get it done then when they call for no heat or hot water they figure that the guy cleans it also they are allways told to call for a cleaning appointment but they never ever do it there was a lint ball in the blower compartment the size of my fist these people have no idea they jut constantly think your ripping off they are out of there minds i did this in one day finished at 11.00 at nite not even a thank you great custermersR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
Great looking job.Do you teflon tape or just dope.0 -
telfon
i use telfon and a pipe sealant called blue magic discovered it about a year ago it's the best stuff i've used i caqn't remenber the manafactor but the stuff is greatR.A. Calmbacher L.L.C. HVAC
NJ Master HVAC Lic.
Mahwah, NJ
- 125 Chimneys & Flues
- 121 Geothermal
- 396 Solar
- 19 Recall Announcements
