B-Pex or Pex-A what's the difference?
Tom Giedraitis
Member Posts: 44
Can anyone explain the difference between B-Pex and A-Pex? I know it is not an O2 barrier as I've seen both with O2 barrier.
Thanks
Thanks
You forgot C-PEX
All three are different ways the PE is crosslinked. The A has the highest % of crosslinking then C and then B. That is why the A is the most $$ then C then B.
Ted0 -
And if you want
more detailed information:
PEX A - Engel method: a hot process that takes place during the extrusion process; cross-linking occurs in the carbon atoms (Rehau, Wirsbo, Mr. PEX)
PEX B - Silane method; a cold process; a special pre-mixed polyethylene based resin is extruded into HDPEtubing. In a second process , the tubing is placed in a sauna to complete the cross-linking process with heat and moisture. This process also produces a less consistent level of cross-linking, with more complicated bonds across the tubing's molecular chain; cross-linking occurs across silicone and oxygen molecules, i.e. weaker (Infloor, Thermalease, Heatway)
PEX C - Irradiation method; a cold process; cross-linking occurs in the carbon atoms (Roth, Stadler-Viega, HeatLink)
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
You forgot Heatlink has PEX-A
they make their own PEX-A now in Canada and it is a little more flexable then the others. It also cost less, I would say about $0.06 to $0.10 per/ft on 1/2" for both non O2 and w/ O2. Check it out!
Ted0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
