a breakthrough
Larry_6
Larry_6 Member Posts: 4
I've had one steam radiator (kitchen) in my first-floor apartment that is furthest from the boiler that never heated up very much. When I'd check the pipe in the basement it would be hot up until a point a few feet from where its riser would penetrate the floor to feed the radiator.
Low and behold, this same pipe (the long horizontal feed) sprang a pinhole leak 2 days ago resulting in a constant drip (sometimes drizzle.) But alas, the radiator is now getting full heat.
This probably points to an obvious problem but please confirm for me. It's a 1-pipe system. Has the problem all along been not enough pitch on this pipe?
thanks
    Steamhead Member Posts: 18,625
    Probably
    the pinhole is leaking air as well as water, which allows steam to reach that point faster. A larger vent on the radiator will cure the problem when the pipe is replaced.
    To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"
    Consulting
  • Larry_6
    pinhole vent
    the thing is that I tried to address this problem last year by placing a large vent at the end of this feed pipe. The configuration looks like this: The feed pipe is an almost- straight run from the boiler. At around 17 ft there's a T feed leading to a riser serving a small bathroom radiator that works fine. At around 26 ft I have a T leading to a riser feeding this kitchen radiator. At 28 ft I have a 6" riser with a large vent atop that readily gets steam and does a lot of spitting and gets quickly discolored.
    This new pinhole is in the main feed a couple of feet in front of the riser to the kitchen. Usually, only the inlet side of the kitchen radiator gets steam (pre-pinhole.)
    Sometimes I just leave the vent off the kitchen radiator altogether and this doesn't help it get more steam.
    Any suggestions?
