Having trouble finding a thread not so old
It had to do with high efficiency condensing boilers VS conventional atmospheric ones. In thre basement? I think.
It's not more than a week old. I can't seem to track it down. It has relevence to one of my pending clients.
Thanks in advance brother Wallies.
Gary
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=296&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Gary
As far as I know, if it is not here on the page, it can't be browsed through. There is a Search above. Have you tried that though ?
You CAN mark a thread to be saved, then when it goes away you can still access it. In case someone happened to still have saved the one you are interested in, they could copy and forward to you I guess. Good luck.
I had several marked that I lost when there were problems and the site went down a couple months ago. drat !0 -
Gary, search for an author
Someone that posted in it, and when you find it, click "show thread"
Noel0 -
search
Gary, I entered "atmospheric boilers" into the search feature. It returned 20 hits, some of which were your posts from the last week or so. Try that, I hope it helps find what you're looking for. djw
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"0
