New Radiant Floor Install
Tom_42
Member Posts: 63
and considering other options. I have heard that radiant floor heating is really good. I have an unfinished basement (meaning the 1st level floor is accesible). Is doing this type of install possible? I would also need to somehow get heat to the second floor. I am just trying to do some thinking about the future. I am considering doing some remodeling and that would be a good time to consider other things as well.
remodeling
Tough to beat a good steam system that is installed and runnign correctly for good heat, byt radiant is a sure bet for even, comfortable and efficient heating. You could go with basebaord heat on the second floor and radiant on the first, which is done a lot. Do yourself a favor and contact a heating pro to help you design a system for your house. Don't try it yourself if you don't have the expertise. Your comfort depends on it.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0
- 50 Industry Classes
