HEAT EXCHANGER
Cesar
Cesar Member Posts: 3
DEAR FORUM MEMBERS,
I HAVE AN OLD STEAM BOILER WITH A HEAT EXCHANGER INCORPORATED IN THE UNIT FOR DOMESTIC HOT WATER. DOES ANY OF YOU HAVE INFORMATION FOR THE HEAT EXCHANGER OF THIS BOILER WITH THE SPECIFICATIONS BELOW DETAILED:
NATIONAL - US OIL HEATING BOILER
"25 SERIES"
I=B=R
BOILER No. 6-25B
SQ.FT.: 1470
BTUH: 3562600
OIL BURNER: 4.5 GPH (ACTUALLY IS WORKING WITH NATURAL GAS)
VALVE CAPACITY: 470
HEAT EXCHANGER: YAM
F 919
552
8 GLNS
I NEED TO KNOW HOW MANY GPM COULD I MOVE THOUGH THIS HEAT EXCHANGER AND THE PRESSURE DROP THROUGH IT.
I LOOK FORWARD TO HEARING FROM YOU.
YOURS TRULY,
CESAR
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    I don't
    recognize that heat exchanger number, Cesar. Is there a manufacturer's name on it?
    Retired and loving it.
