Mixing w/ reset
kevin coppinger_3
Member Posts: 13
on a boiler that is using outdoor reset will there be problems w/ overshooting? I have heard that you should not mix the two because the 3 way will not "understand" the reduced water temp therefore give too high a water supply to the panel/slab that you are trying to mix down...kpc
Style
Your results will depend on the type of 3 way you are using. A three way thermostatic will try to maintain it's preset outlet temperature regardless of input water temperature. A proportional three way valve is flow based and can follow a source reset. Enjoy....Dan
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Keep in mind
with a 3 way thermostatic you will nee about 20 degree warmer water in the primary, or boiler loop to make them operate, and mix properly. Still my choice.
An non motorized manual 3 way ( dumb valvewill not respond properly to changing loads. It mixes on flow only. So if it is connected to a radiant manifold with numerous telestat operators, for example, as more zones open the mixed temperature changes. A semi proportional reset, so to speak!
Just depends on your application how tightly you want to keep that temperature, and amount of control you need.
hot rod
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
