Is there a heating code book for s-8 & s-7
Jim Beardsley
Member Posts: 1
Is there any heating code books for the connecticut S-7
and S-8 heating license? If so I would like some info.
Thank you,
Jim Beardsley
Thank you,
Jim Beardsley
Dan's reading list
has a link to Amazon, Low Pressure boilers, some of the stuff from this book is on the test.
javascript:Amazon('http://www.amazon.com/exec/obidos/ASIN/0826944124/heatinghelpcom')
If the link doesn't work, look at Dans list0 -
s-test
PSI is the company that gives you test,should tell you what topics are on test and what books are needed.I took my s-1 this past summer and passed,,,what fun that was.GOOD LUCK!.....0
- 167 Indoor-Air Quality
