out with old...
we installed over 100 feet of pipe to streighten this one out and moved 10 feet closer to the chimney. got to remove the pld one today and wire it up...
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    Does your ....
    back hurt? How did you get that 215 up on 2 cinder blocks? Nice so far...like to see the final product. kpc
  • David Sutton_3
    David Sutton_3 Member Posts: 160
    Paul keeps his cape in the truck
    But always wears the superhero suit under his sweatshirt,
    we did the old tilt and block, one at a time. i forgot to bring the camera on friday , but will go back on mon to check system, and gets some photos. thanks Kevin,....David
  • kevin coppinger_4
    that's gotta be....
    a HUGE water content system if it has that big a extrol tank. kpc
  • David Sutton_3
    nope just 4 zones with..
    a mega store that was already there, we moved that 15' from where it was, boss told us to use the old tank over it was overkill, 60 would have been perfect.
