out with old...
David Sutton_3
Member Posts: 160
we installed over 100 feet of pipe to streighten this one out and moved 10 feet closer to the chimney. got to remove the pld one today and wire it up...
Does your ....
back hurt? How did you get that 215 up on 2 cinder blocks? Nice so far...like to see the final product. kpc0 -
Paul keeps his cape in the truck
But always wears the superhero suit under his sweatshirt,
we did the old tilt and block, one at a time. i forgot to bring the camera on friday , but will go back on mon to check system, and gets some photos. thanks Kevin,....David0 -
that's gotta be....
a HUGE water content system if it has that big a extrol tank. kpc0 -
nope just 4 zones with..
a mega store that was already there, we moved that 15' from where it was, boss told us to use the old tank over it was overkill, 60 would have been perfect.0
- 167 Indoor-Air Quality
