flow meter
Bryan_16
Bryan_16 Member Posts: 262
a flow meter that will measure up to 30gpm. Will be installed on a gshp, on the ground loop side. Goes on an 8-ton unit. Will make hot water for basement in-floor, garage in-floor, and 2 air handlers. Will make cold water for a/c for the 2 air handlers.
