using copper pipe for steam
Al G
Al G Member Posts: 1
I am installling some additional steam baseboard, 1 -4ft and 1- 8ft along with about a 100' run. I would like to just fit the steel baseboard with npt x female adapters and run copper pipe. Easier to work with , no threader needed, etc.
Is there any reason why this will not work assuming i follow all the guidlines for steam, pitch , drip etc ?
Is there any difference between the fin tube used for hot water and for steam?
thanks in advance for your replies
