Axeman-Anderson Domestic Coil available?
kevin coppinger_4
Member Posts: 2,124
at www.tfi-everhot.com , if they don't have it, you don't need it. kpc
Axeman-Anderson Co. Domestic Coil available?
Does anyone have, or know where I can get: a domestic hot water coil for an Axeman-Anderson Co. coal stoker?
Thanks,
Nevin0 -
Call them.....
@ 570-326-9114 they are located in S Williamsport, Pa. and have always been very easy to deal with....
the part # for what you want is IN-117 if you have the 130
or IN-162 if you have the 260
Make sure you have them send a gasket with the coil and be sure to snug it up after you heat and cool it a few times after installation0 -
Thanks for the posts and the emails.
Merry Walmart Christmas to one and all,
Nevin0
- 167 Indoor-Air Quality
