PB or PE?
Ken_8
Member Posts: 1,640
We are bidding a huge snow melt job and would like your opinion on which is better, cheaper and the pro's and con's about each (polyethylene or polybutylene with a SS or non-ferrous HX (or perhaps SS/alloy boiler - directly piped); and...
A replacement of steel pipe in yet another failed Frank Lloyd Wright in-floor/slab radiant job that has steel pipes looking like swiss cheese.
Both PEX and Copper are off the radar screen.
Whattaya think?
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=68&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
Whattaya think?
I aint no chemist
but many car wash snow melts are using PB.Why is pex out?
cheese0 -
Inasmuch...
as your system WILL have glycol in it, and that glycol WILL have corrosion inhibitors in it, and it WILL have annual fluid maintenance checks, o2 barriers are irrelevant.
So, use what ever tickles your pink. Or would that be whatever pickles your tink...
In any case, both tubes are capable of withstanding the temperatures you will be exposing it to (140 degrees F max).
The only kink I can see would be the transition fittings. Crimp rings for PB are rare and getting rarer.
Smile for the camera!!
Good to see you my friend.
ME0 -
> So, use what ever
> max).
> and getting rarer.
> Smile for the
> camera!!
> ME
I thought that ...
the crimp rings for the Pex and polybute were really the same thing....it has the same crimper.....kpc
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"0 -
Wouldn't be too hard on old Frank
Considering that Frank Lloyd Wright will have been dead 45 years come this April 9th, and the fact that he had a limited selection of materials to work with regarding radiant slab heating, I'd say that any black iron system that has survived 50+ odd years, has fulfilled it's useful life expectancy. Maybe giving old Frank Lloyd W. the "bad rap" isn't really justified.
Just my $.02 from an ardent admirer of the greatest architect of his day.0 -
PB vs. PB
Cost is the reason.
Photo I.D. - optional
Well, along with failed heating systems
most of Wright's structures also have serious structural problems. He may have been a genius designer, but a good builder he was not. When Walter Burley Griffin left his office, there was a huge drop in the quality of work coming from his office.
Dave "Boilerpro" Bunnell
Professional Bach. Architecture, 1989
Illinois Institute of Technology
Chicago, IL.... One of the worlds archtectural Meccas... especially for Prairie School architecture.
Not according to my supplier...
I'd hate to have a leak because I'd used an improper crimp ring. The tool may be the same, but I suspect there is a difference in the crimp ring used, but not being an expert in Poly Suitylene, I dunno...
ME0
- 167 Indoor-Air Quality
