\"HOMART\" Radiant baseboard.
Art Pittaway
Member Posts: 230
Remove the pipe connections and it should just lift right off. Make sure some one didn't put a moulding above it and if the wall has been painted you may have to scrape the dry paint to break the seal. It really is quite simple.
Art
Art
\"HOMART\" Radiant Baseboard Question.
I had a post on this topic a bit ago, and someone had actually heard of this stuff.
We are doing some renovations at the house now, and need to remove it from the wall. There are no visible screws to hold it on the wall. I am thinking that it is hanging on the wall with a bracket. Am I right. Help
Mike0
- 109 Chimneys & Flues
- 5.6K Gas Heating
- 971 Plumbing
- 386 Solar
- 17 Recall Announcements
