water preasure sensor?
Arthur
Member Posts: 216
Not sure if you mean a pressure sensor or temperature sensor. As you say that, If the line preasure drops below the preset temp it stops the flow. temp or pressure??
If you want to sense pressure then use a pressure switch so that if the system pressure falls a pre set pressure the pump will shut down or if you are on temperature then get a thermostat to do the same job.
Water Preasure Sensor?
I have a customer request for a preasure sensor
on a water line..The customer says that the sensor is connected to the pump.If the line preasure drops below the preset temp it stops the flow..
He has seen them in a irrigation system.
Is there anything out there for hydronics0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 960 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
