Rigid Propress!
Jamie_6
Jamie_6 Member Posts: 710
I know I have missed many posts on the subject but was curious who has one, how well does it work, do the joints look nice, what temps. is it good for, and would you recommend purchasing one?
Jamie
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    You can see them all
    just use the "Search" button.
    Retired and loving it.
  • t.speed
    t.speed Member Posts: 11
    ProPress
    I have had excellent results from the ProPress that I purchased about 4 years ago. It has paid for itself ($2,200) in less than 2 years. No failures in over 500 joints; mostly hydronic work.
    Two very minor problems: #1 once a joint is pressed, nasty "ears" are squeezed out that can draw blood if you hit them at the right angle, solution: file down the ears. #2 if you need absolute straightness in some connections, there can be some minor deflections in the crimping process that will skew an aligned tee or 90º.
