DWH recovery rate question
Tom Towne
Tom Towne Member Posts: 25
Hello Guys
I have some questions about my Bradford & White water heaters performance. I use it as a constantly circulating radiant system with 800ft of 7/8 PEX. The water heater is a 50 gal, 65,000 BTU with 80%recovery rate and 3 months old. Flame looks good
My question is this. How can it take 25-30 minutes for this unit to heat the returning water from 118deg F. up to the 145deg F. shut off point. Seems as a 20 deg rise should not take this long. I am just trying to figure out if the unit is working properly. Thanks.
