Garber Oil Filter
rob
Member Posts: 64
Looking for some help/info on a Garber 11R oil filter- need to replace the spin-on cartridge but it is Sunday AM.
Does anyone know if this can cross over to a standard automotive oil filter and the number?? Thank-you!
Garber ?
Rob, I think there is a Wix filter that will cross over. If you can't find that try this. Drain old filter and refill with carb cleaner and pour out, refill with oil,prime this should get you going until proper one is had. Also clean the pump strainer. P.S. Westwood also has a Garber refill now, Hope this helps John@Reliable0 -
In a pinch...
It's either the Wix 33107 or 33352.0 -
Wix
Carquest Auto parts uses Wix filters under their brand name.
al0 -
Garber replacement
Not sure which Garber P/N we use, but it crosses over to a NAPA 3109.0 -
Garber to WIX
WIX 33109 (crosses to NAPA 33109) is a 5.2" high x 3.7" dia fuel filter w/ a 1"-14 thread annd a 2.7" OD x 2.4" ID gasket for various Cummins engines. 33107 is as above but only 4.4" high, and 33352 is as above but 7.0" tall, and used for Cat, Cummins, Nissan, and Komatsu engines. Being fuel filters not lube oil filters though they may be hard to find on a Sunday.
See also: http://www.wixfilters.com/filterlookup/index.asp0
- 87K THE MAIN WALL
- 58 Biomass
- 116 Chimneys & Flues
- 109 Geothermal
- 993 Plumbing
- 389 Solar
