Concrete 'curling' in corners ff. wet installation
We are remodeling and adding to a 1935 bungalow in the Western
Mountains of Maine. In the new part, which is a 30 ft. X 20 ft. area, the heating engineer installed a hydronic radiant heating system, with a wet installation layer of lightweight concrete over PEX tubing, which had a layer of poly laid on top of the tubing (and under the concrete). The concrete was poured in early Dec., and is now 'curling up' at several
corners, such that it visibly (and audibly) moves when someone stands on it. Since we intend to have ceramic tile laid on the concrete in one area, and engineered (K
