cast iron radiant?
Tim Gardner
Member Posts: 183
Which brings me back to the original idea. Is there any steam design that might work for radiant? How about 2-1" steam pipes instead of the 2"? How about dropping it 3 inches below the floor? Or is it just plain a bad idea and steam is just too hot at any pipe size?
can I fabricate an underfloor cast iron radiator
I took out a radiator on my first floor under a dining room window that will become a door to a deck, but now my dining room is a bit cold. Access to the dining room floor from underneath in the unfinished basement is easy.
Using the condensate from my steam boiler for radiant is one good option.
But I had another idea after seeing Michael DiMenna's clever fabricated radiator:
http://forums.invision.net/Index.cfm?CFApp=2&Message_ID=76547.
What about running 2" cast iron pipes off the main between the joists, connecting the far ends with 3/4" through the joists, and then putting a 1/8" vent at the end of the 3.4", and then covering it with insulation below. Cast iron radiant heat! Ignoring time and the cost of the big iron, is this a bad idea?0 -
Toast your wooden floors
Not only would you have hot spots but I'm sure that much heat cannot be good for a floor. You'd probably get splitting and discoloration.0 -
Thanks for answering. So I gather that the reason radiant works is that the heat is spread out over a greater area? Or is radiant a bad idea for hardwood floors in general?0 -
Low temp
The answer is A.
It's the low temp over a large area.
Designed properly, there is not a problem with radiant under wood floors.0 -
Hybrid
You could 'leech' some hot water off the steam boiler, and run underfloor tubing.
Try this:
http://www.oldhousejournal.com/magazine/2003/february/hybrid_hydronics.shtml0 -
Yes, I understand that using the condensate is a good idea, as I said in my original post. But I wanted to explore the steam idea. If it could be done, it would avoid a pump, extra complexity, etc.0 -
too hot
the point is, steam is too hot. Cool enough for radiant under wood and it's no longer steam.
Mark0 -
Hrmmm
This may cost way more than it would be worth but if you could just have cast iron plates up between the joists, big buffer and no hot spots. Your house better be well built... L0 -
how hot can the hardwood get
in a typical radiant floor application?
Thanks,
Tim0 -
I don't think hanging all that weight would help the structure any, but I am curious whether something like that could work.0 -
Floor Convector
Tim, your first idea isn't bad but you'll need a grille in the floor in front of the new door. They make convectors for hot water systems... 8-10" wide by 6-8-10 ft. long. Cut the floor, drop it in and pipe it. You could build your own with a steam emitter below if you have the clearance to the main for pitch, vent, etc.
Don't try to heat "through" the floor with steam, too hot and will toast your floor. You need the linear grille. Make sure to consider convective air movement. Hot air won't rise if there's no cool air to replace it.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 109 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 966 Plumbing
- 385 Solar
- 15.3K Strictly Steam
