How to calculate system volume?
I've forgotten;-(
Let's say I have;
10' Feet of 1" copper
100' Feet of 3/4" PEX
125' Feet of 3/4" copper
150' Feet of 1/2" PEX
How do I find my total system volume? I read in one of Dan's books how to do this using a table of pipe size X liniar Ft. but I can't seem to find it right now and need to figure out how much chemical to add to my system.
*To catch up with me in real time, use AOL's Instant Messanger. My user name is: Radiantfloors
Add me to your buddy list. I've got a bunch of Wallies on my list.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=296&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
Let's say I have;
here's a start
1" copper, 0.043 gallons per ft
3/4" copper, 0.025 gallons per ft
3/4" pex, 0.01834 gallons per ft
1/2" pex, 0.00921 gallons per ft0 -
Curious as to what
chemicals you use?0 -
calculating system volume
Gary,
The expansion tank sizer module in the new Hydronics Design Studio software can be used to quickly calculate the volume of a system containing almost any combination of copper, PEX, and PEX-Al-PEX tubing. You can specify lengths for up to four different tubes as well as a misc. system volume. The volume is needed as part of sizing the systems expansion tank.
Siggy0 -
Buy Siggy's HDS.......
EASILY......the best money you can spend on software!!!0 -
Best Money I have spent
was Siggy's Software.
was Siggy's Software.0 -
Ditto
Best money I have spent since my marriage liscence.
JPEG is now attached
Regards,
PR0 -
ouch even
on broadband that takes some time to load..
Pity the po' fool that tries it with dial-up...
Nice graphics though... I re-did it into jpeg and emailed it to you.
R0
