f.h.w. w/ steam
Bob Gagnon plumbing and heating
Member Posts: 1,373
can i run a f.h.w. loop off a steam boiler up to the 2nd floor. it is about 15 feet above the boiler. if it will work on the 2nd floor does anyone have a piping diagram. thanks, bob
Yep, you can
Be careful with the piping, put a valve on the return by the boiler that you can use to create some back pressure on the pump if it flashes to steam, even with a bypass. Pipe it like this....
http://www.heatinghelp.com/newsletter.cfm?Id=29
Noel0 -
Is a flo control the same thing as a flo check?0 -
yes
fhw with steam
We did a job using this diagram 2years ago. We used the everhot tank and everything. So far its working great.0 -
thanks
for all your help. i just printed the diagram and i'm going ahead with the piping- i'm more confident now. bobTo learn more about this professional, click here to visit their ad in Find A Contractor.0
- 167 Indoor-Air Quality
