Cast Iron Baseboard layout?
Jamie_6
Member Posts: 710
I have done a heat loss for a cast iron baseboard job I am doing and room (A) calls for 6,716 BTU's or approx. 12.5 feet of baseboard. Do you guys stay "tight" with that # or put a little more than the load calls for do no furniture or draperies they may be in the way?
Jamie
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=289&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Contractor"</A>
Jamie
Jamie,
I would say it would depend on the structure. If it's tight , and well insulated you may get away with being a foot short.(don't try this with fintube baseboard!)
Cast iron holds the heat a lot longer than alot of emitters, and if the place isn't a barn, I don't think the difference will be noticed unless the weather stays like it has been here for the last couple weeks. JMHO, Chris0 -
lot O' iron
If your heat loss is done at 180f water rerun it at 140F Then put in a weather responsive boiler . the cast iron will be warm all the time. The comfort is the next best thing to a radint floor!!!!!0
