Attaching pex tubing
I was told by a friend's dad not to attach pex tubing to wire mesh when putting under a cement pour. He said that expanding and contracting would cause the tubing to rub against the metal and cause leaks over time. He said to put sand down and on top of the tubing, then pour. Is this so? Mike
