Steam Boiler 2 Pipe System Problem Excessive heat in basement
Zion Bowser
Member Posts: 2
Problem-Excessive heat in basement,have to turn heat up to 85 degrees to get heat to the second and third floor.There are no bleeders on each radiator,but three in basement at highest points.
Sounds like a Vapor system
Those main vents ("bleeders") may be bad, or too small. You'll probably find that there is one on each steam main and one on the dry (overhead) return.
Also if the steam pipes are not insulated, the basement will get too hot.
Have you tried the Find a Professional page of this site? If you're in or near Baltimore, e-mail me!
To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"All Steamed Up, Inc.
Consulting0
