VECO SYSTEM
Steamhead
Member Posts: 18,432
the Differential Loop on a non-Hoffman system. I saw one installed on an ADSCO the other day.
I'd treat this as a VECO, which is very similar to Broomell and Vapor Regulator Co systems. Use a lot of venting capacity- depending on the size of the system you may need 2 or more Gorton #2 vents installed in or near the Differential Loop.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=157&Step=30">To Learn More About This Contractor, Click Here to Visit Their Ad in "Find A Contractor"</A>
Consulting
Consulting
i have just encountered a veco steam system . the new boiler is 1 year old , with problems . do i treat this like a broomell system ? its installed with a diffrential loop at the boiler and of course the rad above the boiler is capped off...is there any near boiler piping i need to know about ? any info would be helpful thanks0
