domestic hw coil
pj_2
Member Posts: 10
Travis
did ja get my e mail
maybe we can use them for back up coils
we ordered new ones
vinager
we try'd acid didn't get thru
but hey we're will'en to try anything at this point
thanks
pj
we ordered new ones
vinager
thanks
pj
I'm stumped on this one
Did anyone ever hear of a domestic coil blocking up in 3 weeks. We have a customer who's dhwc pluged up with ???
salt from the water softner, maybe ??? Or somthing flushed in from the water main. There are 2 coils w/ 1-1/2"cw in & out, installed by the mfg about 3 weeks ago. They are in a Viking steam boiler. supplying steam and hw to a large banquet facility. Undid the unions on cw side pleanty of water nothing on the hw side, anybody ever experience anyhting like this. Really strange!!!! 3 weeks Any help would be appreciated. We're going to acid wash tomorrow and probably monday, they're pretty big coils. Also who would have muriadic acid on sunday?0 -
This sounds like an unusual failure.
The home centers may have muriatic in the paint department
Mike0 -
Ya know what
Years ago when I worked with mt dad, as a wee lad, I remember..... Somehow a water softner allowed all those beads Zeolite, I think they are called, to wash out and into the plumbing system.
May just as well have been concrete! It took a long time with water and high pressure air to flush that system clean.
Is your softner resin tank very light all of a sudden? I hope not
Not sure I would go on an acid trip, until you determine what you have going on. Acid caused strange things to happen when misused!
hot rod
thanks mike
h.d not my favorite place has it.
hot rod
this may be the case it's the only thing the mfg guy's and I can think of. we'll find out tomorrow, but I gotta wash it, can't shut'em down all kinds a things going on.
but hey 3 weeks , new coil,
oh well We're getting paid
thanks
pj0 -
Maybe a good place for
a Filter. I know it's commercial, so it's going to be a big flow rate but even a gang of three(?) "whole house units" would strain the junk before the coil. Unlike computers, garbage in doesn't mean garbage out.0 -
plugged coil
Have the water tested after the filtration system.the heat from the boiler may be driving something out of the water and plugging the coil. Had it happen on a smaller scale in a residential boiler. The treatment guys said salt would flush it out and we used 5 Lbs of table salt in five gallons of hot water and pumped it through the coil and voila!! you have to know what you're dealilng with befoe attacking it. Be very careful with that acid....remember, someone will injest the water that comes through that coil after you're done. FLUSH>>>FLUSH>>>>>FLUSH and then test it before you put it back in service!!!!
Ashrae \"Fundamentals\"
Was looking thru an older copy the other day and found a graph which showed how much lime would precipitate our of water at various temps. 120F water had only a very short rise in precipitant but as the temp got up to 180 it was major poundage. Get your water analysis done for the supply water and also for the softened water. If it is city water you can get it from the water dept. Good luck tomorrow!0 -
white viniger
White viniger is the best thing I have ever used on flushing coils. Get the boiler real hot then pump in the wite viniger into the coil and out into a bucket and keep it cyceling through for about twenty minutes.0 -
attempted flush w/ muriatic acid
Wow these coils are plugged solid.
We did get some purple looking stuff , I suspect its rosin if my memory serves me , the softner has rosin in it and its redish brown color we did not get thru either coil yet.
Letting the acid set in the coils overnite. In the mean time got hold of the mfg and they're going to make a new set of coils.
Hey Jack that was interesting this water temp is 200 + and the mfg's guy said the last coil was blocked solid w/ a white cement. Heh watd'ya think calcium carbonate or lime.
Yeh we'll have the water tested and yes it's city water, er a little water co.
This is a pain in the a, told the owner we need to put in big **** direct fired comm. gas water heaters . he agreed "cha ching $$$$$$$$$$ god I love it when they listen.
thanks guys
pj0 -
Send me your fax #
and I'll send you a copy of this page. What exactly is the use for this high temp water, if you don't mind my asking?0
