Help! Cant find threaded monoflo tee's
I'm putting together a one pipe hot water system with threaded iron pipe. I've checked into Taco's Venturi tee (not available in threaded) Bell & Gossett's Monoflo tee (not available in threaded) Even Armstrongs have only sweat fittings.Ideally
I'd like to get iron fittings. I'm even tempted to make my own by inserting a reducer or a washer into a threaded tee but not sure it will perform.Any suggestions?
  • Boilerpro_3
    Boilerpro_3 Member Posts: 1,231
    I've got a source..... Email Me
  • Jason Roberts
    Jason Roberts Member Posts: 11
    Threaded Monoflo
    Hi Bill,
    I need 1 1/4" x 3/4. Approximately 16 pieces or 32 depending on the final design. I'm putting cast iron baseboard downfeed about 10" from the main.
    I'm in Toronto
    Thanks
  • bigugh_4
    bigugh_4 Member Posts: 405
    Look at this site
    WatsonMcDaniel.com then speciality products then suction tee
