LP, Black pipe elbow inside wall?
Steve Eayrs
Steve Eayrs Member Posts: 421
DO any of you use flexible gas pipe and fittings? Like gastite, or wardflex? We still do black iron and pull the threader out sometimes, but its sure a time saver on some jobs.
Steve
  • LP, Black pipe elbow inside wall?
    Chatting with a friend about a new barn (outside Binghamton, NY area) with living space above. Builder ran black pipe inside the finished wall for an LP gas heater. Seems that there is a threaded elbow connection inside the wall.
    Is this an "OK" situation?
    I get a little nervous about gas connections that are hidden. I asked if it was ever pressure tested - it is unknown if it ever was tested.
    Patchogue Phil
  • joe_14
    joe_14 Member Posts: 138
    fittings
    i belive you can put black iron fittings in walls . copper fittings in walls is a no no . yes it has to undergo a pressure test before it can be concealed.
    joe.g
  • bob young
    bob young Member Posts: 2,177
    according to nyc plumbing code black threaded piping systems is the standard for natural gas piping. testing and inspection is mandatory local regulations for propane gas may vary
  • All Gas Piping
    needs to be pressure tested. The tests for propane are different than for natural gas. If you send me an e-mail with your postal address or FAX number I can send you some information.
  • Steve Ebels
    Steve Ebels Member Posts: 904
    Black pipe gas fittings
    You can not use a union inside of a concealed cavity or space. Double tapped fittings, like a bushing, are a big no-no anywhere. Tees, ells, couplings and reducer couplings are acceptable. ALWAYS pressure test!!!
  • Mark Eatherton1
    Mark Eatherton1 Member Posts: 2,542
    Never understood that...
    Why is it illegal to have a reducing bushing in a concealed space, but its ok to have a reducing coupling???
    Some things just really baffle me, and some times it's REALLY obvious:-)
    ME
  • Bushings and couplings
    Bushings can crack very easily , especially when you use one to reduce down to the next size - I cracked many a 1 1/2 by 1 1/4 bushing . Reducing couplings on the other hand are much stronger - never cracked one yet . Had some sandhole leaks in them though .
  • If I recall,
    the code says CAST IRON bushings are against code. Not ALL bushings.
    Honeywell includes blind bushings with thier gas valves. Just not cast iron ones.
    Noel
  • Tony Conner
    Tony Conner Member Posts: 549
    If There's...
    ...only one pipe size difference, like Ron says, there's not much meat left after the threads are cut. It's kind of like a sch 40 close nipple. (I don't like sch 40 close nipples for that reason.) I'm also not a fan of malleable iron bushings and plugs (especially the hollow-core ones). I've had a number break off when you try to remove them, after they've been in for a while. Steel plugs and bushings cost quite a bit more and besides, if the code folks say "no bushings", they won't care what the material is. Even where steel bushings are permitted, you need guys on the wrenches that can tell the difference in the material by looking at them. Don't count on the supply house guys to know steel from malleable - some do, but most don't.
  • bigugh_4
    bigugh_4 Member Posts: 405
    It is to EASY
    To install socket weld gas lines in spaces that are to be concealed. Do the future a favor and do this kind of work. Always pressure test the system. A welded system should last the lifetime of the building. Screwed piping is for places that will never be concealed. think aboudit just makes sense!
  • Tell me more....
    ... I have not heard of socket weld gas lines.
    TIA
    Patchogue Phil
  • bob young
    welded gas piping
    not a bad idea but probably not practical or cost efficient modern plumbers ??? don't even want to thread pipe i can just picture them carrying a welding machine. ,they are using metal tubing w/ comp. joints .. in n.y.c. we weld anything over 2 " [nyc code ] threaded joints have always been a problem.
  • Steve Ebels
    Wardflex et. al.
    > a time saver on some jobs. Steve
  • Steve Ebels
    Wardflex et. al.
    We use flex gas line only when the number of fittings and threads per 10 feet of pipe exceeds 6. It's just my personal rule of thumb. The only other times are when you physically can't get black pipe in the space it has to go.
