Frankie
Radiant Wizard
Member Posts: 159
What would you do
If Josie sang the blues
Cause her radiant wasn't
Working Today.
She had it installed
by someone who new it all
It was a sad, sad day.
And then she called you
to fix her fue
and now she's happy all day.
Happy Thanksgiving!!! Call me later. I've got a solution for that other job.
Working Today.
to fix her fue
Josie did call
And was singing the blues , the heat ain't workin and she's hot as a boiler flue. The electric water heater used for the job...is sucking down juice like a big fat slob. The suspended floor method which the contractor chose, does'nt work at night and poor Josie's feet froze. So now she's mad,called consumer affairs, the contractor had the audacity to suggest hot air! So here i come in with the "RadWiz" design, and when the job is redone,Frankie and the Wiz are both gonna shine! NOBODY BEATS THE WIZ!0
- 167 Indoor-Air Quality
