Vitodens
Tom Bradd
Member Posts: 34
Hi folks Here is the latest picture of a Vitodens with 3 way mixing valve and zone valves v300 120 gal storage tank w/r zone panel I love mixing valves. Just a nice touch of thermometers on the return and supply
why the...
different brands of PEX in slab and staple up? kpc0 -
8-32?
Looks to me like you are using and 8-32, I see no external pumps on the return side of the boiler. Do you have any concerns with the limited input of the Vitodens 8-32 and the recovery time you will have with 120 gallons tank? The tank is rated for max output at 255,000 bth.
I am in agreement with your system if the need is for dump, large tub, etc. and all high mass rfh that will not suffer if it sees no flow for 25 minutes.
Just curious,
Henry
Vi - Midwest0 -
Kevin we were called in to finish the job and I dont use kitec as a main line of tube so I finished it in Wirsbo
Henery I was worried about the 8-32 with that big of a tank but they had a large dump load of 13 gpm for a fancy shower the the H.O. said no problem adding the 120 gal tank,But he wanted the max efficency for his heating.Plus they didnt think they would use the shower system every day. Pretty expensive toy eh ?0
- 50 Industry Classes
